95 Toyota - V6 No spark
nichols
Collinsville, VA
Hey anyone have any problems with the ignition modules on these? This is a low mileage truck just picked it up did a much needed tune up and a later that day the truck stopped producing any spark. I've had problems with LC and GM ignition modules but new to the Toyota pick-up, anything else I might be missing. Any options beside the dealership for replacement?
Ignition fuse ?
check 'em all, under dash and hood. cheap easy fix if thats it.
All fuses are good, fuel at rail. The wierd thing is this happened all of a sudden. I was in a hurry, pulled into the driveway and was going to back into my spot when I stopped to put in reverse the motor died and as not fired up since. One other thing before servicing no check engine light after tune up check engine light came on and stayed, I was just bringing the truck home for the weekend and planned to trackdown someone Mon. to check codes. Before the tune up this truck had a bad skip but the plugs and wires were shot along with a fuel filter that was clogged, truck has a 109k apparently with little maintenance.
check the timing belt, no belt, no spark (dizzy no turn)
Ditto...given the poor maintenance history, my bet is on the timing belt.
:beer:
