95 YJ Transfer Case Shifter
2000F150SAS
Fuquay-Varina, NC
I just installed a 2” body lift and need to remove the Transfer Case Shifter so I can weld the extension into the handle and can’t remove it. I’m working in the truck and have removed the shifter boot and see two square holes at the bottom of the handle. What do I need to do so I can remove these?:confused::confused:
Thanks
1995 Wrangler
There is a spring clip inside. Seems like we had to slide something flat inside to release the spring. Can't remember the specifics, it's been a while.
