95 YJ Transmission
aidanemma
greensboro NC
I was running down the highway in 5th gear then all the sudden this loud grinding started. I pulled off the road and then started back again the loud grinding started again but it only does it in 5th gear. I have had a small transmission leak when it heats up. Does this sound like a low gear oil issue or is 5th gear going. If it is 5th going can you just purchase that gear or will a transmission rebuild kit do the trick. thanks
Is it a AX5? ( behind a 2.5L)
