96 F-350 Service Body 7.3 Sold!
justjeepin86
Winston-Salem, NC
I picked up this truck from here not running and went through it. It runs like a top and drives great. The body on this truck is fantastic with no rust to be seen. There is a decent dent on the back of the cab, behind the driver door. It looks like something got caught up in between the bed and cab. Shown in pics
It also has a ladder rack that's not pictured
The interior is in excellent shape. There is one small tear on the driver side seat and the dash has one small crack.
When I pulled the valve covers to do the glow plugs, it was spotless inside. Extremely clean inside this engine.
All bays on the bed seem to be dry minus 1. There are some old mount holes on the top diamond plate that need to be resealed.
Cold A/C!
Brand new A/C compressor, condenser, fresh charged
7.3 Powerstroke Auto 141,450 miles
6 New Tires
2 New Batteries
New Headlight Assemblies
New wipers
New Valve cover gaskets and glow plug harnesses
New Motorcraft Glow Plugs
New Lift Pump
New air and fuel filter
New Drive Belt
Oil has been changed 2x since it was sitting for so long. Just to be safe.
Both tanks were pulled and cleaned with new pickups installed. Both tanks and fuel gauge work.
Fresh trans filter and fluid. It has a new front pump seal installed.
The torque converter is a ford reman with sticker on it. No Idea on the transmission, but it shifts great.
One new front hub and rotor and new wheel bearings in both front sides.
New front calipers and brakes
New rear brakes, including wheel cylinders and new drums
New inner wheel seals on rear hubs
Title in hand
It will have replacement right side mirrors when sold.
12k
