I've got a '97 crew cab thats giving me some trouble with the TPS, or thats what I thought (think) . I haven't had the truck too long but it doesn't seem to give me the throttle response I think it should. It sometimes has a hesitation to it and has surges at random times, or a complete nonresponse to pedal movement, then it throws the CEL. I put in a junkyard pedal with no improvement, maybe a little worse than before (complete shutoff of engine a couple times). I ordered the Dorman replacement TPS which gave a little better pedal response for the first 2 miles I drove it but still didn't fix hesitation/ CEL problem. I'm guessing the TPS wiring is tied in with some other stuff so does any body have any ideas what to check for next?
I didn't want to start up a new thread so I will update this one
Updated info:
So I fixed the original problem, which turned out to be the ICP. I changed it out and it ran great (better than before but still no real power). Anywho, I started it up and drove it couple miles down the road to work. When I went back out to crank up and leave, fired up and immediately died. The tac is working, HPOP full, changed oil, #22 and #8 fuses good. I did change fuel filter and clean the screen out between the fuel bowl and FPR (?) which was all but stopped up. I did get it to start about 4 cranking cycles after the filter clean but nothing since. Anybody have a spare IDM laying around? Any other ideas?
Updated info:
