97 TJ 2" Budget Boost Lift
NCJeepin
Conway, SC
If I put a 2" Budget Boost Lift on a TJ, I can fit 31's on there eaisly right?
u dont even need to put that on 2 run 31s. i got 1.75 and am runnin 32s with plenty of room. 00 tj
yeah i saw rustys had a 1.75 and new bump stops for 99.00 on special.
i got bds spacers and love them. but if you just dont wanna spend money unless you really need to then u can just put the 31s on there
I run 31s on my 2000 TJ daily driver with no lift. And yes, I have had it on the trail too and no rubbing of the fenders. The only thing is the 31x10.50s rub the suspension if I turn the wheel all the way to one side, but a lift wouldn't solve that, only wheel spacers or rims with the proper backspacing. I am running the stock rims.
I don't know how all these guys run 31s with no lift. I ran 31x10.50 Trxus MTs with the 2" BB and they still rubbed pretty good when flexed out.
Easy. The tires you ran measure around 31" and most " 31's " are lucky to measure a true 30" new with no tread worn off.
<><Fish
I ran 3.5" backspacing on my wheels. The tires would hit the top of the inside of the fenders, not the fender wells. I don't see how backspacing would help that issue. If more backspacing, the would've rubbed on the inside of the fenders, if less backspacing they would've rubbed on the fender wells. They were gonna rub one way or the other.
