DannyH
smokey burnouts
- Jan 10, 2014
- Stanfield, NC
Swapped my 97 TJ to auto for rock jumping capabilities, so I have pretty much every part you need to swap your TJ to a 5sp.
Parts List:
AX15 from a 1997 Jeep Wrangler Sport 4.0
Clutch master, slave and line
Manual PCM
brake/clutch pedal assembly
transmission mount
Flywheel and clutch
Crank to throw out bearing adapter
Manual transmission tunnel cover
Neutral safety switch harness
Shifter and boots (not pictured)
Transmission is going to need a rebuild. All gears did work before it was pulled, but 1st gave trouble going into gear(bad synchros). I drove the jeep into the shop and swapped to an automatic. Every part is there to make this a plug and play swap after the rebuild.
$600 obo
Parts List:
Manual PCM
transmission mount
Flywheel and clutch
$600 obo
