- Mar 20, 2005
- Morganton NC
Recently I installed a Taurus fan in my Heep. I got the idea from Pirate and used their suggestion as to the relay.
They call for a NAPA part # ST85 commonly used on golfcarts for continous duty higher amperage use.
I wired it all up like a Ford Solenoid. I didn't work. I got out the meter and checked everything, still nothing. took it back and got another. Still,.... nothing. I couldn't get it to actuate. So knowing some of you run the Taurus fan, diceided to give that a try. I called Rich. Rich used a different method and was too fast to let me know what it cost. Ok so I had already over spent, but was determined to use what I had. He suggested I call Greg Slade. Greg had the answer! Seems unlike the Ford solenoid(relay), it is not self grounding. so, of the two small poles for wire connections, one if for the +switch, and the other for the -ground. Worked like a charm. I sure appreciate the help guys! See, even us old dogs can learn new tricks!
Oh and forgot to mention. Greg had a little salt to rub into the wound also. Seems his SO works for Advance Auto, and she was able to cross the Napa Number over to an Adance number, and get one rated the same for half the price. Live, and learn.
