A ton of Differential and Axle parts
Walt
Indian Trail, NC
Please TEXT to 7O4 TWO 66 SIX ZERO 88
When texting refer to the item number in the list. For example: "Hello I'm interested in Item 6, Ford Explorer Axle Shaft"
DO NOT post here as I dont come here often
There is a picture below with corresponding item number.
2 GM Chevy 8.5 8.6 G80 Posi Carrier Gov-Lok 30 spline 10 bolt Silverado Suburban - $249.00
3 GM CHEVY G80 10 BOLT 8.5 30 SPLINE GOV-LOK POSI LSD Older Trucks 98-Down - $230.00
4 GM Chevy 8.0 G80 Posi Carrier Gov-Lok 28 spline 10 bolt Colorado Trail Blazer 8" - $299.00
5 GM Chevy 8.0 3.73 Ring and Pinion Gears Colorado TrailBlazer Envoy Canyon 8" - $149.00
6 Ford Explorer 8.8 Passenger/Right Rear Axle Shaft RH SPORT TRAC MOUNTAINEER - $49.00
7 Vari Lok Jeep Grand Cherokee WJ 99-04 Dana 44 Passenger/Right Rear Axle Shaft RH - $99.00
8 Jeep Grand Cherokee WJ 99-04 Dana 44 Passenger/Right Rear Axle Shaft Rt RH - $99.00
9 Jeep Wrangler 4340 Chrome-Moly Axle shaft 30 Spline Dana 44 Yukon TJ JK 002 - $149.00
10 Jeep Wrangler 4340 Chrome-Moly Axle shaft 35 Spline Dana 44 Yukon TJ JK 002 - $149.00
11 Jeep Wrangler 4340 Chrome-Moly Axle shaft 35 Spline Dana 44 Yukon TJ JK 001 - $149.00
12 BRAND NEW TWO (2) Rear Suspension Shock Absorber Monroe 5601 Scion xA, xB 04-06 - $49.00
13BRAND NEW TWO (2) Shock Absorber Gas Magnum Monroe 34930 Ford F-150 250 350 450 - $40.00
14 Outer Axle Shaft Dana 30 WRANGLER CHEROKEE WAGONEER COMANCHE GRAND YJ TJ XJ ZJ - $24.00
15 SIX (6) National Oil Seal 710863 Jeep Wrnagler JK 07-18 Front Axle Dana 30 44 - $49.00
16 GM Chevy 8.5 8.6 3.23 Ring and Pinion Gears 10 bolt Silverado Suburban GU5 - $119.00
17 BRAND NEW Yukon Gear & Axle YP SJ-297X-202 U-Joint Dana 30 44 Super Joint - $299.00
18 GM Chevy 8.0 3.42 Ring and Pinion Gears Colorado TrailBlazer Envoy Canyon 8" - $149.00
19 GM Chevy 8.5 8.6 3.42 Ring and Pinion Gears 10 bolt Silverado Suburban GU6 - $119.00
20 Yukon Chromoly Inner Front Axle Dana 44 30 Spline RH 33.6” Jeep JK Rubicon 002 - $175.00
21 Yukon Chromoly Inner Front Axle Dana 44 30 Spline LH 19.8” Jeep JK Rubicon 002 - $115.00
22 Yukon Chromoly Inner Front Axle for Dana 30 27 Spline LH 18.8” Jeep JK 002 - $95.00
23 Yukon Chromoly Inner Front Axle for Dana 30 27 Spline LH 18.8” Jeep JK 001 - $99.00
24 ZA W38875 Chromoly Inner Axle Dana 30 32.36” JEEP Wrangler Cherokee TJ XJ YJ ZJ - $99.00
25 CHROMOLY *CUSTOM* Inner AXLE SHAFT DANA 30 4340 Jeep Grand Cherokee WJ 99-04 - $50.00
26 Ford 9" Inch 35 Spline Eaton Detroit Locker - $499.00
27 FORD 9.75 LOCK RIGHT LOCKER POWERTRAX F-150, EXPEDITION - $249.00
28 Dana 44 Aussie Locker 30 Spline XD-14430 Jeep Chevy Ford - $199.00
29 Dana 44 LOCK RIGHT LOCKER - $50.00
30 CHRYSLER 9.25 LOCK RIGHT LOCKER POWERTRAX DODGE Ram Durango Dakota 002 - $249.00
31 CHRYSLER 9.25 LOCK RIGHT LOCKER POWERTRAX DODGE Ram Durango Dakota 001 - $199.00
32 Dana 30/44/GM 8.5 U-Joint Full Circle Snap Rings Clips ~100 pcs 1.28mm 1-3/16 - $20.00
33 Dana 44 Jeep JK Front Axle Shaft Left Driver 30 Spline 1350 U-Joint - $75.00
34 Dana 44 Jeep JK Front Axle Shaft Right Passenger 30 Spline 1350 U-Joint - $75.00
35 Jeep JK Dana 44 Front Axle Shaft Right Passenger 30 Spline 1350 U-Joint - $69.00
36 Jeep JK Dana 44 Front Axle Shaft Left Driver 30 Spline 1350 U-Joint - $69.00
37 Jeep JK Dana 30 Front Axle Shaft Right Passenger 27 Spline 1350 U-Joint - $69.00
38 Jeep JK Dana 30 Front Axle Shaft Left Driver 27 Spline 1350 U-Joint - $69.00
39 CHROMOLY Inner AXLE SHAFT DANA 30 Spline YJ TJ XJ ZJ WJ 4340 W38811 Dana 44 - $69.00
40 CHROMOLY AXLE SHAFT DANA 44 30 4340 Blank Unsplined 36.5" Long - $49.00
41 BRAND NEW G2 CHROMOLY OUTER AXLE STUB SHAFT JEEP JK DANA 44 4340 1350 Rubicon - $85.00
42 BRAND NEW CHROMOLY OUTER AXLE STUB SHAFT JEEP JK DANA 44 4340 1350 Rubicon - $85.00
43 BRAND NEW CHROMOLY OUTER AXLE STUB SHAFT XJ YJ TJ JEEP DANA 30 44 4340 - $120.00
44 CHROMOLY OUTER AXLE STUB SHAFT XJ YJ TJ JEEP DANA 30 44 4340 002 - $99.00
45 CHROMOLY OUTER AXLE STUB SHAFT XJ YJ TJ JEEP DANA 30 44 4340 001 - $99.00
46 Dana 35 4.10 Ring and Pinion Gears 001 - $119.00
47 Dana 44 4.10 Ring and Pinion Gears - $119.00
48 Dana 44HD 4.10 Ring and Pinion Gears Super 44 44a Corvette Grand Cherokee Rodeo - $199.00
49 Ford 8.8 3.31 Ring and Pinion Gears - $119.00
50 Ford 8.8 3.55 Ring and Pinion Gears - $119.00
51 Ford 8.8 3.27 Ring and Pinion Gears (1) - $99.00
52 Dana 30 4.10 Reverse Ring and Pinion Front High HP OEM - $119.00
53 Dodge Chrysler 8.25 3.73 Ring and Pinion Gears Jeep XJ Liberty - $99.00
54 Dodge Chrysler 8.25 3.55 Ring and Pinion Gears Jeep - $99.00
55 Dodge Chrysler 8.25 3.92 Ring and Pinion Gears Jeep - $99.00
56 Ford 7.5 3.73 Ring and Pinion Gears Ranger Mustang - $119.00
57 GM Chevy 7.5 3.08 GU4 Ring and Pinion Gears GMC S-10 Blazer 7.6 7.625 - $119.00
58 GM Chevy 7.5 3.42 GU6 Ring and Pinion Gears GMC S-10 Blazer 7.6 7.625 - $119.00
59 GM Chevy 7.5 3.73 GT4 Ring and Pinion Gears GMC S-10 Blazer 7.6 7.625 - $119.00
60 GM Chevy 7.5 4.10 GT5 Ring and Pinion Gears GMC S-10 Blazer 7.6 7.625 • - $119.00
61 Dodge Chrysler 9.25 3.92 Ring and Pinion Gears - $119.00
62 Dodge Chrysler 9.25 3.55 Ring and Pinion Gears - $119.00
63 Ford 9.75 3.73 Ring and Pinion - $119.00
64 Ford 9.75 3.31 Ring and Pinion - $119.00
65 GM Chevy GMC 9.5" 3.42 Ring and Pinion Gears ALL YEARS - $139.00
66 Ford 9.75" Open Differential F-150 Expedition 9.25" - $120.00
67 Ford 9.75" Limited Slip Differential F-150 Expedition LSD Trac Lok - $149.00
68 Jeep Grand Cherokee WJ Carrier Hydra Vari Lok Quadra Drive Posi Locker LSD 7/16" - $299.00
69 Dana 44 3.73 Ring and Pinion Gears 7/16" Bolts Jeep Grand Cherokee WJ 00-04 44HD - $119.00
70 BRAND NEW DANA SVL Dana 44 4.89 Ring & Pinion Reverse Front High Ford 4.88 - $129.00
71 Dana 30 Carrier Loaded Open 3.73 and up - $99.00
72 BRAND NEW Motive Gear Dana 30 4.88 TJ Ring & Pinion - $99.00
73 BRAND NEW USA Standard Dana 44 4.56 JK Ring & Pinion - $119.00
74 BRAND NEW Motive Gear Dana 44 4.88 THICK Ring & Pinion TJ Rubicon - $119.00
75 GM Chevy 8.5 8.6 3.73 Ring and Pinion Gears 10 bolt Silverado Suburban GT4 - $119.00
