a tool i use?
JonathanS
Member
Harrisburg NC
what is the tool i use to trim my fenders on my truck so my tires will quit rubbing.. if there is a pic of the tool that will work to... (i work at sears, so craftsman wink ;) )
If you can't think of a tool to use, then you should probably not use any tool someone tells you to use.
But, if you want to try anyways:
Messy way - Sawzall
Not so bad - Air cut-off wheel (requires an air compressor)
Ghetto - Hammer
Most efficient - jackhammer (not available at sears)
What part of the fender are you needing to trim, and on what type of vehicle?
BODY SAW
Use this, happens to be the cheapest one in the Sears catalog, but probably the best working/built. Still over priced.
just hope you have the air to run it.
Kevin
Masking Tape and A jig saw
Air Nibbler
Sawzall
Cut off tool
You can find the body panel cutter by the left handed screwdrivers at Harbor Freight. It's a cheap hand operated tool...... About $35. I haven't seen one online but most carry this tool in the store.
