rokntoy FUCKIN SLAYER!!! Joined Sep 2, 2006 Location Elkin, N.C. May 18, 2010 #1 I have a 96 tahoe with the abs light on. How can I get it to go off or do I have to take it to a dealer?
sweetk30 New Member Joined May 2, 2010 Location horseheads,ny not nyc May 19, 2010 #2 need a scanner to clear the code. but most abs codes come right back so you will need to find out why its on. might be a wheel bearing going in the front. this is the comon cause up here in the north east rust belt. any good local shop other than dealer can do this work also. no need to go to the dealer and spend big money.
jeepn-jason Well-Known Member Joined Mar 20, 2005 Location Greensboro May 19, 2010 #3 Hey jason, check out parrish tire in Dobson. Two of the guys that work there are members on the board here. They will take care of you.
GCncsuHD Charlie Daniels with a torque wrench Joined Jun 18, 2007 Location Salisbury/Statesville May 20, 2010 #4 Probably a wheel speed sensor. The abs module is separate from the PCM, so either a dealer or a shop with a TECH 2 scanner will have to check/clear the code (Not the same as the little scanner advance/autozone has).
wranglerrambler Well-Known Member Joined Dec 28, 2006 Location oxford,nc May 25, 2010 #5 take the bulb out
sweetk30 New Member Joined May 2, 2010 Location horseheads,ny not nyc May 25, 2010 #6 newer gm also trip the brake light bulb when abs is active for a code.
