ABS
Yes, you will still pass. The ABS system is not inspected as part of the process. Only the mechanical and e brake is inspected.
They cannot fail you solely for an ABS concern.
I'm an inspector...
I'm an inspector...
X2 I'm also an inspector. As long as the brakes work correctly and don't have any excessive travel in the pedal or any leaks, you're good to go. You will not fail just for an ABS light.
depending on year its an emissions issue. i'm not sure on this. i've been told by 20 diff people that its 95+, 96+ 99+ so i have no clue on that part.
