AC doesn't work, recommend a Charlotte/Mt. Holly/Gastonia shop
You try charging it? They have kits at Vatozone. Its easy.
yes it is r12 and you would have to have the system retrofitted with r134 o-rings, txv or orfice tube depending on the type of system it has. I dont no how much a shop would charge you but ive retrofitted a few cars and the part all together range from 100 to 150$.
You dont HAVE to retrofit the 12 system to 134a. NAPA has some stuff called "Freeze 12" and it goes in where the R-12 was with no modifications needed. Make sure you have a thermometer in the vents when charging, it is easy to overfill. Did that on my wifes van and worked well til it leaked out again.
