Agree fuse first.1st check fuse, then if you have power, i would see if you are getting power to the blower motor, make sure to check it with the fan switch turned on, then if you have power there, then it may be the fan, if no power there then check the switch.
p.s. Ditch the high-maintenance gf while you can.
FAR FAR FAR from high-maintenance
