My Garage is underpowered for what I use (240V Welder Compressor are good) but the 120V side I really would like a couple 20A circuits. (30A bonus) Everything is 15a and the box is full so I can't add anything that I'm aware of. My thought is to use one of my (2) 240V 50A plugs and make an adapter that has an 120V 30A plug (For our Camper) and a standard 120V 20a or a couple 15A plugs for grinders, 120V welder, Portable 120V AC unit Etc. Can this be done without burning down the house/garage?
I usually pull the AC off the garage door outlet since it seems dedicated and not much else is on the circuit, however I can't run the AC and a grinder or 120V welder or a chop saw on the circuit. I've got to the point twice now that the breaker has gotten so hot that it won't stay on when the AC kicks on nothing else on that circuit that I'm aware of is running. Forgot to turn off the AC when using Chop saw or welder. So I've replaced the breaker three times now in the past 5 years and I'm wondering about options and hoping the adapter could be the easiest solution. Only time I ever use both 240V 50A is when the plasma is being used, otherwise I have one that I'm hopping to tap into for the more common 120V high draw items I use.
I have 2 of these receptacles
I'd like an "adapter" for these, Maybe just mounted to a small piece of plywood
Anyone know if it can be done with the two 120V legs from the 50amp?
