91oneton
- Sep 10, 2005
- conover nc
Pro Comp Straight Edge LED Lighting Systems
Pro Comp is proud to announce the latest addition to its popular line of performance lighting products, the new Straight Edge LED (SEL) light systems. These new lights feature state of the art construction that can handle off road abuse without difficulty.
The heavy duty construction earned these Pro Comp lights a 15.6 G-Force rating. Each SEL series L.E.D. light bar is equipped with 3-Watt CREE LED bulbs, the finest in the industry. The dual purpose beam pattern is the best of both worlds; you get the 60 degree light pattern for your up close and personnel needs and the 10 degree light pattern for your long down-range needs. The SEL Series is 100% waterproof and comes standard with all marine grade wiring and connections.
The engineering and quality that goes into each light should make it your first choice but with the lifetime warranty it makes it your only choice for a SEL-LED light bar.
Pro Comp Straight Edge LED Light Features:
Available in 4", 8", 12", 20", 31", 38" & 46" lengths
12-Volt Input
Rugged 6061 Aluminum Housing with Heat Sink
CREE 3 watt LEDs, 90% efficient optics
Durable Lexan Polycarbonate Lens
Includes Marine-Grade Wiring Harness, Relay & Connectors
50,000 Hour Lifespan
Submersible up to 10', IP 68 Rated Housing
Mixed Beam Pattern (60*/10*)
Limited Lifetime Warranty
4" $149
8" $219
12" $299
20"$439
31"$639
38"$779
46"$959
Thanks
Brandon
12-Volt Input
4" $149
8" $219
12" $299
20"$439
31"$639
38"$779
46"$959
Thanks
Brandon
