air shocks
Its not ideal but you can definitely do it. Sways bars help control the roll but I would change the oil level in the air shock. With the shock upright let the nitrogen out and compress the shock all the way, pull the schrader out and fill the shock up with shock oil. Then put them back on the vehicle and fill with nitrogen to set your ride height. This will give you a little bit of help with body roll.
Alex
Yes. If you paid for a good sway bar you could make the air shocks work and be a decent drive but the coilover would cost around the same price and be better in about every way.
