is that momentary a push on - push off type switch?
I dunno if Id get a momentary switch and haveto hold that thing on the whole time i want it locked up
It's a toggle switch, center position is Off, Up means Lock, Down means Unlock.
On thsi unit, the circuit is only active for about 2 seconds while the motor is transiitoning the fork, then it trips the limit switches once the unit is locked, no more need for power. Same for reveersal/unlocking. Technically you don't need a momentary switch, as the limit switch built into teh unit automatically cuts the power anyway, however to me it's an added precaution - this way if one of the limit switches fails, I still won't be left with the motor tryin gto run and burning up.
If you wire up an LED to the "locked" signal line, then all you have to do is hold the switch ON until the line turns on, then let go.
Here's a great diagram of how to do it using the limit switches, but no relays:
Or if one were a real slacker, you could just wire this DPDT momentary on-off-on switch right to the power/2 wires of the motor and be done with it - just have to be careful about how long you hold the switch on for. Problem is that if the switch gets stuck, your motor will be toast.
