userbmx1315
builds more then wheels
- Feb 8, 2008
- Bessemer City, NC
I added an anti wrap bar to my XJ, now when I accelerate it raises the rear now. What causes this?
How long is it in relation to your front 1/2 of the leaf spring?
What angle is the upper portion of the anti wrap bar at ride height?
How much separation is there between the mounts on the axle end?
The separation distance between the mounts at the axle end doesn't matter if its a triangulated solid bar. Spread mounts are just for stiffness so the axle can't rotate, so unless you're having some really bad compliance problem where things are bending under load... You draw a straight line between the anti wrap front pivot and the axle housing, and nothing matters about the rear mount at all if its a fixed mount.
I would think the position of the front pivot versus the front leaf spring shackle position is probably the key here. I think that's what XJsavage is saying too. That is probably creating too much anti-squat. The height of the anti wrap bar front pivot versus the shackle height will affect that too, and the pivot height versus the axle housing center height i think.. I've never messed with anti wrap bars before but I'm looking at pictures and figuring out the geometry effects in my head. Like all suspension geometry, its just pivot locations and linkage lengths.
Sounds like you're creating a really interesting problem where the anti wrap bar is making the instant center move; that's really what I'm trying to say.
My vehicle dynamics is a little rusty, and then there's the whole "leaf spring" ugliness...
Gordon said:Here's the skinny. on a muscle car leaf spring rear the rule of thumb is that the instant center is located on a line through the center of the axle parallel to the ground. and it is 2/5 of the total leaf spring length in front of the axle. This works OK with smallish tires and flat leaf springs but it isn't very close at all with typical lifted 4x4. When I was in college I wrote a TK Solver program that calculated instant center location for leaf spring vehicles using the whole spring compliance. I don't really know how accurate that was either, but the first rule of thumb, that the instant center was always about the height of the axle center line seemed to hold true pretty well for the examples I tried.
Anyway with the Sam's Offroad style traction bar where the traction bar is bolted solid to the axle housing and then mounted to a shackle the traction bar its self is not the link at all the shackle is the link. So if you draw a line through the upper and lower shackle bolts and a horizontal line through the axle center line where those lines intersect should be your instant center for your application.So if you draw a line through the upper and lower shackle bolts and a horizontal line through the axle center line where those lines intersect should be your instant center for your application.
Hope that helps
