bannerp
- Dec 4, 2011
- Newland NC
1994 Suburban 350 TBI auto trans. A little back story truck was towed in to our shop last year say August found no fuel pressure replaced pump, strainer, fuel filter. Replaced dizzy cap, rotor, plugs and wires ignition coil.Dude basically said hey I'm gonna restore this thing it was my dad's make it right. Got the plugs out 3 out of 8 were covered in severe oil ash and carbon. Got truck running and it oil smoked severely bad. He said he knew it smoked and always had.
Fast forward to October towed back in found distributor pickup was bad no injector pulse. Replaced with new unit truck ran fine.
Fast forward to End of November oil cooler line blew apart he kept driving it till it locked down. Replaced engine with Jasper reman. Noticed he had it to another shop and the TPS, IAC, and EGR valve were all new. Got the engine installed and it runs like crap for about 1 minute. Choking spitting sputtering pouring black smoke like it was running real rich. So I Replaced coolant temp sensor and pigtail no change. Replaced map sensor no change. We let him drive it for a few weeks and still no change. Now I didn't have access to an OBD1 GM scan tool so basically j was just going off what I knew could be the culprits. Coolant temp reads correct. Map voltage is correct. Cleaned all throttle body vacuum ports and passages. Still runs rough when cold. Once you let it go about 1-2 minutes it clears right up runs perfect rest of the day. I've checked injectors they don't leak after truck is shut down. Here's the rundown
New TPS IAC valve EGR valve ignition coil distributor fuel pump ( pressure checked within spec) timing is 2 degrees with spout unplugged. New Echlin Map sensor New Echlin coolant temp sensor. Ran axillary grounds to battery and block to frame. Map is reading 4.18v koeo map has ground no resistance. Coolant temp reads correct. No Codes in ecm.
Any input would be appreciated. I don't like throwing parts on cars without diag but till we got our hands on an Old Snappy Modis I had no choice. These are the things I have checked. Thanks NC 4x4 Fam.
