Are Steel Rims OK? and Backspacing of 98 Chevy Rim?
JonBoy
Hampstead NC
Ok i have to questions first I am wondering if anyone knows the backspacing of the stock 88-98 chevy 6 lug alloy rim? Second are steel rims ok or should I stick with the stock rim since I cant afford much better. Also how long before steel rims start to show rust? Sorry getting back to first questions I will be looking for a 16x8 rim and think that I will want something with less back spacing pushing the wheel out just a little. So basicly 1" less backspacing and 1" wider rim should put my tires out about 2 inches? Right? Anyway I dont want to look like I am on skates but think it would look better moved out just a little. I will also be going from 265's to 285's and if I can find one a 1" body lift.
Steel rims are just fine. Strong and they don't break. They will bend, but can be put back into shape with a hammer. Less backspacing is rough on bearings. Also to be concidered is the tire rub you will most likely get when turning. Most people I know that have used body lifts, didn't like them. just s few thoughts to concider.
I'd much rather have Steel rims than Aluminum.... the only beneift that I know Aluminum offers is lighteer weight... Personally, I'll not ever put Alum., rims on my CJ.
Also, Steel rims can be repainted with specialty equipment such as Rustoleum. It's kinda why folk use black rims and bumpers. Matching isn't much of an issue.
J
I had a set of black steel rims on my old ford. The paint lasted about three to four months befor it would show sighns of rust, but i drove on the beech a lot more than most people do so yours should last a lot longer. When they did start to rust it only took an hour to hit them with a wire wheel and respray them. As far as strength is concerned I bent the crap out of three out of five that I had.
Also to be concidered is the tire rub you will most likely get when turning. Most people I know that have used body lifts, didn't like them. just a few thoughts to concider.
That's what I've got on the Jimmy I bought. The body's lifted 3 or 4 inches, but the 31-inch tires hit the frame, the edge of the fenders and in a bounce, even the top edges when I make a sharp turn. And that's just on streets.
These are on what seem to be the stock aluminum 4x4 wheels. I've been looking for some regular 235/75r15's to put on for everyday.
