2001 Yamaha Kodiak 4x4
Parents bought it new and it has been a great quad up until a month ago. Quit running, carb was leaking, etc.. Brother in law decided to have a go at fixing it.
He applied the shotgun approach: replace everything versus finding what could be wrong. Still doesn't work, so my parents brought it to me. I went over the work he did and everything looks good. All connections are tight, no corrosion, etc..
Work done by bro-n-law:
And it gets better.... when it does start and run, it is idling as if it is at half throttle. No matter what adjustments I try with the idle screw, air screw on the carb, it stays idling that high. So high that it wont go into gear.
Thoughts?
- new battery
- new coil
- new spark plug
- new starter relay
- replaced the other two relays (pink and white ones)
- had Yamaha dealership rebuild the carb and they say it is tuned to factory specs
- new air filter
- fresh gas
Thoughts?
