bigblockburris
- Mar 20, 2005
- Mt Pleasant NC
I am starting an axle swap on a 1967 M715.
I have the front covered (Dana 60) no problem.
I will be running 38"-40" tires.
Rear has me concerned.
The springs on the rear are 54" apart. I have a full width 14-bolt FF out of a 1 ton Chevy truck. Backing plate to backing plate on my 14 bolt is right at 54". Everything I read says you have to run rear disc. Again, no problem, but even disc are close and some people have had to mount the calipers upside down???!!?? The calipers hit the rear springs.
So I gave up on a 14 bolt and found a Dana 60 that was wider. Then a fellow board member brought it to my attention that the axles in the 60 were the weak link and would not stand up to mild 4 wheelin' with that size tire with out an axle upgrade.
I also have a Dana 70HD out of a Chevy Dually. Its draw backs are size (ground clearance), cost of parts, and width.
So my question is.
Which axle?
Corporate 14 FF
Dana 60
Dana 70
Thanks in advance!
BBB
So my question is.
Which axle?
Corporate 14 FF
Dana 60
Dana 70
Thanks in advance!
BBB
