Axle shims
NCJeepin
Conway, SC
Are there any draw backs from using angled axle shims when you do a lift?
Im fixing to start he resto on my 89 YJ and part of it will include a 4" lift and a 1" body and motor lift...
Im thinking with a 1" motor lift, and rear axle shims will really help the driveline angle of my YJ.
Any comments/suggestions?
Thanks in Advance
rear shims are ok, as long as they are the good kind made into the spring pack itself.... ( different degrees available too)some of the cheaper ones can actually take up too much space for the spring pack centering bolt, casuing the axle to shift from the leaf spring a little... ive used both and have had no problems .
Steel shims only. Don't use aluminum.
I'm getting ready to lift my jeep yj also with a RE 4" lift, does it really help alot to lift the motor. If so how much. I'm worried about the drivline angle too. I don't have the money to spend on a slip yoke eliminator so this might help me out for the time being.
