AXLE SWAP
BLUEZUK
BISHOPVILLE SC
so i have put yota axles under my 88.5 sammy but my problem is the rear emergency brake cables .the sammy cables are to short to reach,and i cant see how to interchange the yota ones to the sammy. any suggestions
Since the driver and passenger side cables connect in the middle,I used the stock cable for the driver's side and made a longer passenger side cable with regular 1/8 - 3/16 cable. Fab up a simple bracket o hold everything in place and you can use the parking brake like it was intended.
As easy as E-brakes are to do, id make em work either using mismatch cables or by doin the Tcase brake
Cut them off, leave it in gear. Do it with my YJ and it works great. Just be careful if you are on a REAL steep incline
Line locks when you're on incline.
haha just ask Matt (Jeepinmatt) how well these 2 setups combined work on inclines haha... maybe he'll chime in
