- Apr 18, 2005
- Greensboro, NC
I took BK out for a first trip test run to URE this weekend. Took my 16 year old friend, Josh, with a new learner's permit, and hooked up with 89wrangler, BigRedB2, BugNut1228 and Rubicon700.
Steve's NTH Commando had starting issues on the trailer at the Outpost. A shot of starting ether got it going but it continued to cut off and he was forced to turn around on Dickey Bell trail and head home. The rest of us continued on and rode several trails until around 1 p.m. when we all headed over to DPG for the B.S. fest.
The BK is set up right now with a 2" spacer lift, 33x13.50 LTBs, front fenders trimmed to the flare crease, welded D35 rear and LockRite D30 front.
Josh drove the whole day and did pretty good for his first time! He got the first body damage when he took the hard right line on Budwiser and dinged a rocker panel. But he made up for it when he put a matching ding in the other side on Kodak Nothing major, just a scratch.
The BK did good, running street pressure on the LTB's it made it through some pretty good mud holes with no problems and hooked up good on the rock climbs. With some rocker sliders Josh would have made it up the middle line a Kodak but I wasn't wil to put that much BD on it right now so he backed back down and took a different line.
The engine is tired with low compression on #1 cylinder, and had some power issues on the hard pulls but some of that could be gearing too, stock 3.54s. I'll tinker with it a bit and consider the SBC I have on a stand for a swap this winter.
Jerry, Rubicon700, did great in his long arm Rubi with 35" ProComp MTs. He had no problems on any of the trails/obstacles going wherever he wanted. Good rig, good driver!
Reed and Holly, BigRedB2 and BugNut, made it up everything with a little spotting and skinny pedal in their open diff cruiser.
All in all a good day, good to put some names to faces, BK needs some work. You CAN run 33" tires on a 2" spacer lift with minor trimming but you're going to get some front fender self clearancing and a 12.50 tire or less backspaced wheel would help stop the rubbing at full lock but for what it was it did fine and we had fun!
