89wrangler
Not a new member
- Oct 22, 2005
- Bostic,NC
I am working on a 21 Gladiator for a buddy that has a really annoying vibration you can hear/feel when driving. He has had it worked on at various places and can’t get rid of the noise. I have it narrowed down to the spider gears in the front axle. The passenger side has the axle disconnect and everything is smooth when rotating the wheel.
On the driver side when rotating the hub, you can feel/ hear the ratcheting for the lack of better term. I removed caliper and bracket and ruled out wheel bearing. So I removed the diff cover and it appears to be the spider gears. You can rotate them about a 1/3rd of a turn, then they lock up/stick. Takes a lot of pressure to hold the ring gear to get them to go past that point and then they turn free again. There is some pitting, but nothing I see way out of the norm.
@Jody Treadway have you ever run into this? Could there be anything else causing them to not rotate freely. I am going to pull the axle shaft and see if it changes anything.
Any input would be appreciated! Thanks
