Barnes 4WD Fabricator's Corner
Barnes 4wd
Etowah NC
These are some of the parts and pieces that will really help your project along. They can save hours of time consuming work. We have all kinds of parts to put the finishing touches on your project. If we don’t have what you need just ask, we might be able to make it.
https://www.barnes4wd.com/Crossmember-Mounting-Set_p_112.html
Crossmember Mounting Set
https://www.barnes4wd.com/Four-Bolt-Tube-Flange_p_48.html
Four Bolt Tube Flange
https://www.barnes4wd.com/Single-poly-bushing_p_161.html
Single poly bushing
https://www.barnes4wd.com/Trick-Tab_p_160.html
Trick Tab
https://www.barnes4wd.com/DOM-Sleeve-Poly-Bushing_p_137.html
DOM Sleeve & Poly Bushing
https://www.barnes4wd.com/DIY-Fabricators-Corner_c_8.html
brad, i need some tube with a 3/4 ID to make sleeves to pass through the frame. got any?
Dave,
I just saw this, I do not have any DOM that size at this time. I do have some with a 9/16" that we could bore on the lathe.
Let me know if you still need it.
