Barnes 4wd
- Aug 6, 2007
- Etowah NC
Barnes 4WD TJ / LJ Stubby Winch Bumper Steel
The Barnes 4WD TJ Front Bumper is laser cut from 3/16" steel and is formed on a CNC Press Brake. This is a high clearance bumper that offers the protection that you need without getting in the way on the trail. Our bumper uses eight factory mounting holes to attach the bumper to the frame. This bumper can be used with both factory and aftermarket sway bars. This design keeps the winch low and close to the grill for improved protection and to maximize air flow. D-ring mounts are 3/4" thick welded inside and out and accept a 7/8" D-ring. Plus they are made in the USA!
