Barnes 4wd
- Aug 6, 2007
- Etowah NC
The Barnes 4WD TJ Front Bumper is laser cut from 3/16" and is formed on a CNC Press Brake. This is a high clearance bumper that offers the protection that you need without getting in the way on the trail. Our bumper uses eight factory mounting holes to attach the bumper to the frame. This bumper can be used with both factory and aftermarket sway bars. This design keeps the winch close to the grill for improved protection and low to maximize air flow. D-ring mounts are 3/4" thick welded inside and out and accept a 7/8" D-ring
Jeep TJ Front Bumper, Stubby Steel
The Barnes 4WD Winch Fairlead Mount installs between the winch and the bumper so you can mount your Hawse or roller fairleads.Winch mounting bolt pattern is 10.0" x 4.5".
