Barnes 4WD YJ Rocker Guards
Barnes 4wd
Etowah NC
The Barnes 4WD Yj Rocker guard provides both the best in tub protection and functionality. Our rocker guards are made from 3/16” steel that is laser cut and CNC bent so that they will fit every time. They extend from wheel well to wheel well to make sure that your entire tub is protected and tie into two of the tub mounts so they can be abused every time you wheel with our worry. The Barnes 4WD rocker guards not only protect 6” vertically of your tub but also maximize under the tub protection as well with extended steel section under the tub. Our Rocker Guards also come with counter sink mounting holes and Stainless Steel Mounting hardware and lock nuts. These will Work with all body lifts.
https://www.barnes4wd.com/YJ-Rocker-Guards_p_187.html
Thanks for your business
Like most Saturdays we are here packing orders. Give us a call if you need something.
wont those fit on TJs?
Do you offer a Military Discount? Also what would shipping be to 28306 or can I pick them up?
Yes we do! With the Military discount they would be $307.44 to your door. You are more than welcome to pick them up though if you like.
Thank you for your Service!
