Mountain Ram
- Nov 15, 2005
- VA
I have all the mid-late 70s chevy K20 front end stuff to do a disc swap on my '95 Dodge rear D60. I have done this before on other D60s and it should be straight forward. Except of course- the studs for the chevy aren't big enough at the knurl for my '95 rear wheel hub.
After searching extensively- it appears the studs in my '95 are actually for the HD 9.25 rear axle and have a .666 dia knurl (I think this is a sign) and almost everything else uses a .620 or .625 knurl dia (chevy is .625). Obviously I have a Bastard axle!! I have gone thru every wheel stud manufacturer possible and can't find a stud that will work. If the studs aren't a press fit at the knurl- the lugs will never get torqued...
Moving on to the rear wheel hub- I know this is a D60- I have been around long enough to know the difference. I looked at the bearing numbers and they are for the D60. I believe if I can find a pair of '94-'98 Dodge D60 wheel hubs, I should be good to go. Of course- it appears that these aren't available from the standard parts stores...
At this point- I am open to anything- I just want to get the brakes on and get this thing rolling again...
TD
TD
