Beadlock Opinions
HelpMyZ
Fredericksburg, VA
I'm running a 42x14x17" iroks and now I'm looking for some beadlock wheels for 'em.. I've been looking for something like a 17x10, but can't find much for options at that width.. I have found some 17x10 trailreadys for like 381$ a piece, some 17x8.5 walker evans for about 375$ a piece, the poison spyder, spyder locks are a 17x9 and are about 360$ a piece. OMF has thier 17x9 and some 17x10s but they are OVER 400$, so I'm needing advice/opinions... anyone have anything for me?
thanks guys!
almost forgot to mention: I'll be running them on a 95 YJ with a chevy d60 front and 14bolt rear if that makes any difference
if you have steel wheels buy the weld on kit & find a good welder to glue them together
I run the same tires on one of my jeeps. I am partial to the stauns for the dbl beadlock and the light weight. they should be cheaper even after you buy wheels.
I have used the weld on kits on my other jeep w/33s and my only complaint is the weight. You will be more likely to tax your parts with that much weight spinning.
Walker's are the hotness...
Any reason why you're set on 10" wheels? My Trailready's are 9" wide, and the 42's fit just fine on them.
Going narrower would really open up your options, as you've seen.
Look around here. There's a thread about how slow they are. No personal experience here cause I have a tough enough time just keeping my chit rolling and charging batteries to do beadlocks and the like. Someday though.
