Setting up my steering and don’t see a decent way around putting 2 slight bends in my tie rod to clear the diff cover. I’m using Dodge UB outers that have the stock arms pretty high. It’s mocked up with 1” offset heims.
Tie rod below and drag link above was the plan but I hit the diff cover at about 22deg of steering to drivers. Clears fine to passenger
The tie rod clears the diff if mounted above on the knuckles, but then I’d have to find a way to double shear the top on the passenger side and there isn’t a ton to build off of. Also may have frame interference in uptravel.
I think a 20deg bend at each to get about 2” offset will work. I’d switch back to straight heims too. Any major concerns with this plan? 1.5x0.25w and I will have hydro assist attached to it.
