spykosshow
- Oct 13, 2005
- Raleigh, NC
Anyone have a good place to get grade 8 bolts? I need two for the bellhousing of my aw4. I'm in north raleigh, so the closer the better.
Public hardware
http://www.rigging.net/Bolts.html
It's the bolt with 3 lines at 90 degrees to each other.
It might just be me, but I will not go into fastenal for anything. I can not tell you how many customers they screw over, I hear it once a week![]()
BTW do they still have a minimal charge?
Quoted for truth. I've recently started buying only grade 8 bolts. I usually buy more than a need and keep the extra in a card catalog I bought just for stuff like that. I don't want to be stuck with grade 5 crap when I need grade 8 so I only buy the good stuff. Also, grade 8 is typically less prone to rusting.Basically the same as a grade 5, which is anywhere. Auto parts stores, lowes, or a real fastener house.
I *try* to use grade 8 anytime I buy bolts, even if the strength is not required... Only a little more, and quite a bit stronger.
grade 8.8 is about the same as a grade 5 if you want strength in a metric try a 10.9
I was gonna look at work, we might have them there.
You're better off with what you have, the right part for the job.
and they are grade 8 (we slack in the other sizes, only two of the three pitchs for each size above 6)
