gavan
- Jul 12, 2005
- Houston, TX
Should your brakes stall your engine in low/low with the clutch engaged in a manual tranny vehicle?
The braking system is the stock pedal (long throw) to 1 inch wilwood masters to front standard GM calipers/rotors and rear metric GM calipers/K1500 rotors
My Heep has a healthy 4.0 to a t19/stock d300/D44's with 4.88's. Final reduction ~80:1
Preliminary testing shows good pedal feel at street speeds. Stiff, but very acceptable for manual brakes, and easy to lock up all four wheels.
Low/low just bogs down the engine till the EFI decides it needs to bump up the idle a little bit (4.0's are great for that - mixed blessing) then it drives right through the brakes.
Of course, popping the clutch eliminates that problem.
Am I expecting the brakes to do too much? I know over running the brakes is relatively common on auto's, but I had not heard of the problem with manual trannys.
Are the brakes sized wrong? All of my looking and numbers massaging show a chevy caliper and a one inch master with no assist works out to about a 7.5:1 pedal ratio, which is about what the CJ has. Would stepping down to 7/8's or 3/4 inch bore help? Single piston Chevy calipers need alot of fluid, and I would be worried about running out of stroke with a 3/4's master.
For safety reasons , I would like the brakes to kill the motor in low/low, but I guess the bottom line is, even at red line, you are only going 6.5 MPH. Even if the clutch fails, you can yank it out of gear relatively easily.
