brake conversion
dkg1869
stedman
popup_image.php
I found these on the ruffstuff wesite. Does anyone have these. I would like to know if they work well or not.
Looks like a rear disc brake conversion bracket. Never see one by these guys, but it's just a bent piece of steel so I'd say it's probably pretty reliable. I believe it's one of the best mods you can do to an early 4 runner or hilux.
they said to use the toacoma calipers but do I use the rotors too Or the chevy ones like everyone else. Does anyone know where the install site or instructions are.
Its a very straight forward install.......
I will try and make some time this weekend to make one up......
These are designed for the late model taco calipers (95 1/2 & newer), the ones with the low pattern. Mostly used during a SAS so you don't have to throw away those expensive front calipers and rotors......
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
So these are for converting a hilux solid front axle to tacoma 4 piston calipers and rotors?
Edit: I finally found it in the website. It's so you can use taco calipers instead of GM stuff for a rear disc brake conversion.
