Rich said:Here's what worked like a charm on my 3500...
put the rear axle on 2 jackstands. loosely thread 2 lug nuts back on, but leave some room between the drum and the lug. start the engine, get it up to ~25mph, and stomp the brakes. Works like a charm.
This is assuming you have the type of drum that slips over the lugs, by the way.
On my Toyota, there were 2 threaded holes.. thread 2 bolts in evenly, and it pushed the drums right off.
Rich said:which...the bolt holes, or the lugnut trick? the lugnut trick is on my Dana70/80 under the Dodge, the bolt holes was on my 2wd 'Yota, but is the same for all Toy drums.
krehel24 said:All that will work good...If the shoes have not cut a grove in the drum, making a lip on the inside.
