Brake help...ford dana 44
blazed00
Wilmington
I need some help. ive searched and keep getting different answers. I need extended brake lines with the correct banjo to fit the axle on my truck. 79 f150 dana 44, thanks
Im not sure if this is what your asking but if you need extended brake lines check jeffsbroncograveyard.com they have all sorts of parts for that truck just look for 78-79 full size bronco parts and most interchange.if that axle is swaped into somthing else then it would help to know more info hope I helped
Ok so I looked at your blazer build funny thing is I have a 1st gen s10 an im seriously considering doing the same axle swap .if I was in your position I would consider converting your front brake line to a single drop down line that splits on the axle and goes to each caliper that the way the factory did it for that axle and when I put a 60 under my f150 I kept the same setup because it works good and if I do my swap ill do it that way but im sure you have abs pump and other junk to complicate stuff hope this helps
Yea they are still on there. I guess I would just have to figure out how to route the lines with the factory master and prop valve on my truck. That's why I was seeing if they had 2 seperate lines
