brake line question
cgm147
salisbury
question where is the best place to get brake lines when doing this one ton swap? i got the adaptors for the master cylinder on order from sky but not sure if i just need to get extended chevy brake lines.... i guess the question is does chevy extended lines mate up to the toyota hard lines or do i need a custom set made... :driver:
No just install new ends on the hard lines to match your rubber lines, very easy and cheap.
so basically you can get an adaptor for the axle lines also? not sure i follow
i havent bought any brake lines for the front yet and it didnt come with any so i just need to buy extened chevy lines and adaptors to the toyota hard lines?
The chevy stuff will be a standard NPT where your yota will be a metric pipe thread. As said before an adapter will be needed or cut the hard line and switch over to the fittings needed for it to work.
