GubNi
8 lug disc brakes?
- Mar 20, 2005
- Jonesborough, TN
I have a 96 F350 4wd diesel. The problem is it has virtually no brakes. With the engine off it has some brakes, but with it running the pedal goes to the floor. It goes about 80% then slowly goes the rest of the way.
I have put on 2 new (not reman) mastercylinders, right front caliper (bleeder broke), new rear shoes, and ebrake cables. Most of the hard lines have been replaced. I have bleed through about 2 gallons of fluid and even bled the porportioning valve. I tried another booster and it didn't help so put the original back on. I also replaced the sensor that plugs into the master cylinder at the end.
At this point I've done everything and have no more ideals.
I have not replaced wheel cylinders (they aren't leaking)
I have not replaced any rubber hoses (they are not dry rotted or swelling up)
I have not replaced the left front caliper
I have found that the right rear backing plate is bent about 3/8" in at one side which might be causing a problem with the shoes seating.
I'm sure something I've done is wrong or it's another problem that I haven't thought of.
