Ok, I'm going to pick the brains of the forum members...
2002 Silverado 2500HD with a 8.1
2 weeks ago I had to do an emergency stop on the hwy to avoid an idiot merging last mine. Full on panic stop, ABS engage etc... Barely missed him.
When I started moving again, the front axle was shaking like a mofo around 50mph for some reason. It never did so before.
I was 2 miles away from home to I pushed on and when I made it in the driveway I realized the right front brakes were locking up. Thick white smoke, heavy brake smell etc...
I let it cool overnight and the next day I took it for a drive. Came back home after 5 miles, same thing happening again.
On a whim, and since they needed pads and rotors anyway, I shotgun new calipers, pads, rotors and hoses in the front. Same results.
I did plenty of testing so here is what happens : When I press the brakes, the right front caliper locks up. Leave it alone for 45mn/1h and it slowly releases. Press the brakes again and the same thing starts over.
I did unbolt the master-cylinder from the booster, same problem.
The weird thing is, if I put a big screwdriver between the pads and rotor, I can pry the caliper open and everything is fine until I press the brakes again. So they're dragging, preventing me from spining the tire by hand, but not clamping hard enough that I cannot push the pistons back in.
Maybe it's an issue with the pressure relief in the master (???), so I'm going to swap a new master tomorrow, but realistically, I'm out of ideas.
One thing to note, from time to time, I have the ABS light that comes on and off, due to a bad sensor (maybe ?), but I don't think it's ABS related because of the fact that the same problem happens every time I press the pedal. Same thing when the engine is off, ignition off, or on.
Thoughts ?
Thoughts ?
