Jeff B
Thanos was right
- Dec 23, 2006
- Lincolnton N.C.
D30
Wj knuckle swap
Barnes 1 ton offset TRE steering kit,
4340 shafts and Spicer u joints
new Spicer ball joints less than 1K miles
1/4" welded diff cover
artec truss and inner C stiffeners
Spicer ring and pinion 4:88 gears
Lokright locker
tabs for hydraulic assist
Bar pin eliminators
1700$
8.25
Motive 4.88 gears
spartan locker
Iron rock truss
yukon 1541H shafts
comes with the u-bolts and plates
rear shock relocation brackets
both axles full of lucas 84/140.
(Anti warp brackets will be removed)
500$
2200$ if purchased together
Wj knuckle swap
Lokright locker
Bar pin eliminators
1700$
8.25
Motive 4.88 gears
spartan locker
Iron rock truss
yukon 1541H shafts
500$
