- Jan 3, 2015
- Boone NC
because of so many many negative comments on these axles, thought i would start a debate to really find some facts/truth/personal experiences with these axles from all different types of wheelers!!!
ok so i know i'm fixing to start a huge ordeal/debate on the CAD topic BUT WHY NOT: why does everyone hate them so much?? the splines on the axles are HUGE and will never brake, the u joint is the same size as the rest of them, technically speaking 2 smaller shafts same diameter as one long shaft is stronger and harder to break, and the supposed to be "weak" link Collar is only weak when the CAD fails and does not engage/disengage all the way (ask me how i know lol) I've ran the D30 Disco on 9 jeeps and only one ever broke collar cause i didn't fix the engagement system and "thought" it was good but all the others including my current 88 xj with it are replaced and hooked up to strong vacuum that i know and control and never had a problem. i've broken many ujoints on these axles from turning all the way while spinning too much but the collar that everyone says is the weak link has only failed on me and customers (including the ford truck customers) when the CAD doesn't engage/disengage properly so i really think people should highly reconcider their "tests" on these axles. Last but not least point to make about the Disco axles is the housing: the housing is lot more durable than regular D30s or whatever uses the CAD because of the extra big collar they put there so not as high a chance to bend the axle tubes and not so much need for Gussets. I realize this post is going to start some major bashing but i just never could understand the hate on these but also feel if they are properly maintained and properly used (properly being emphasized here), they are no weaker but rather very possibly bit stronger than regular. Every customer with jeep or mostly fords that come to me with broken collars is cause they tell me they "always" engage on the fly or while rolling and they hear a pop and 4wd quits working...go figure.
another point as explained to me long ago: take 4ft 2x4 wood brake it in half. ok good. take those 2ft pieces and exert the same force on them to brake in half again....won't happen with same force applied because of the shorter length of the same rigidness mathematically requires more force applied to brake the 2ft pieces. The CAD axles themselves are very similar in this same application...2 smaller axles which have bigger splines and ends are a lot harder to break than one double the length shaft same diameter. i probably didn't explain this as good as a friend did to me long ago but i think i've made the case good enough.
