Yes it's a D44 but Haynes only refers to the earlier "c clip" version, which is what I was expecting to work on.My 98 rodeo that I had, had a D44 in it.
Already talking to them not much help thus far.
That's exactly what I tried but I could not get the studs to set. I have got the driver side axle shaft out and can get in there w/ a ball joint c clamp and have driven in four so far that way.You shouldn't have to pull the shafts to replace wheel studs.
I have an isuzu 44 sitting in my shop right now and iirc there'll be enough room to drop a stud out the bottom, do one at a time.
Knock old ones out with a bfh then press new ones back in with impact/big ratchet and stack of washers. As long as you can do one, you can get to all of them by spinning the shaft to the spot where you've got access. Good luck.
