I'm having some issues with my 22r on Propane. The truck ran amazing last week. This week brought the suck. It all started when I pulled the dizzy in order to change the ps pump with ease. When I put it back in I noticed that it lost alot of power and throttle response. Saturday at Mtn city I still felt the lack of power and we adjusted the timming because the truck was loading up, sputtering and it was no kinda good. After the adjustment it ran awsome for about 20 seconds. It then started doing the same thing again. It would load up to the point of backfiring but once I let of the gas it would idle fine. I pulled over and the truck cut off. We checked the timming again and it was right on. I had a full tank of propane and after checking the lines...I was getting propane before and after the lockout but nothing was comming out of the converter. I thought the converter was bad but now that doesn't seem to be the case. It's my understanding that it takes vacume to open the diaphram..which opens the plunger to release the propane into the mixer supply hose??????This vacume would be created by the motor turning and would have to come from the mixer. I tested the vacume by covering the supply inlet of the mixer with a piece of a plastic bag. It wouldn't even hold the bag to it. What could be the cause of the lack of vacume. Could I have damaged something inside the mixer? I wasn't running an air filter
