blueoval98
- Jul 7, 2005
- Lexington N.C.
I have a couple ?'s concerning my 84 Silverado 4X4.I just removed the 700R4 trans and went back with a th400.Was a used trans/tcase combo(th400/208).I installed it with a new convertor,modulator valve and vacume line,shift kit and fluid/filter..now for the ?'s...
1) When driving it shifts fine and FIRM.When coming to a stop it only downshifts to 2nd gear.At the stop can manually shift it to low and back to drive and it will take off in 1st gear other than that it tries taking off in 2nd...Suggestions???
2) I also noticed when the trans was out.The truck has the 4 wire plug that is supposed to hook to the dist. someone had used the plug from the dist side with wires cut and some taped together with it plugged into it.The current dist in the truck dosent have this plug.only the wires that connect to the cap..The truck will not fire and run without that plug someone made plugged into the harness..With this being setup like that could it be causing issues with the timing ,such as advancing it cousing it to hurt the power output of the truck????
Thanks in advance for your knowledge and time,
Paul
Paul
