CAN I RUN 35'S ON MY TACO
CAROLINA ROCKRUNNER
BFE
I HAVE A 2001 TACOMA STD CAB 4X4 I JUST INSTALLED A 3 INCH SUSPENSION AND 3INCH BODY LIFT I AM WANTING TO RUN 35X15X15 TSL OR A 36X13X16 TSL WILL THESE FIT WITH THE 6 INCHES 0R DO I NEEED 33'S. THANKS
CAN YOU TURN OFF CAPS LOCK??
I don't have much knowledge about the Tacos, but I would say that 15 width is going to create serious problems without more lift. I would say you either need to go down to a 33, or something more like 12.5 width, and it will still be close.
Sure, they will fit.
base_media
Run a 255/85 on your stock wheels if you're worried. 33.4x10. Most 35s don't actually measure up to 35", so I'm sure that you could clear one. The height isn't so much what you need to clear, but the width (a 12.5" wide tire will probably brush up against your a-arms on a stock wheel).
Depends on how much backspacing the wheel has.... but usually those are 4.5" BS wheels. That wheel might be a little wide for a Taco, depending on how much lift you have.
the 35's will be fine but that wide of a tire is probably gonna give you issues unless your wheels have a lot of back spacing
that 15x8 wheel with 12.50 tires will look fat. It does kinda give the illusion of a wider tire and the bulge always looks good on a yota I think.
Disagree, I've been running 33x12.50s on my XJ w/15x8s for 2 years and they look and wear normally. Gotta be careful not to overinflate but they work fine and air down really nicely.
thanks for all the info
its been a hell of a week but installed the 6inches all by myself i guess galloway will be getting most of my pay check on monday
you can run 36x12.50 tsl's on 15x8 wheels but they will rub the frame. 35x15 tsl's will rip your fenders to pieces. i have the same setup as you and i'm currently running 35x12.50 pro comp xtreme mud terrains and they fit fine
