rockhardpeterkin
- Sep 25, 2007
- Asheville Raleigh
Has anyone ever ground out the center holes of there wheels? mine are 1/4 inch to small so i was thinking about grinding off an 1/8 is this possible?
Thanks Ben
Thanks Ben
but you'll want to measure at least the bolt circle, & see if they are exactly the same. To do this, ( on a 5 hole rim) you measure from the center of one lug hole to the center of the 2nd hole away from the one you start with. If it's got 6 holes, I think it gets measured from the center of one hole to the center of the opposite hole. If these measurements aren't exact then you may lose a wheel. The lugs will work themselves loose, & you may never see it coming. If any of this sounds a little harsh to you, then I did a good job with my explanation!
