The chains you see hanging are now chains. The lower, spin, and go under the tire for more traction. That way the are ready when needed, and they don't have to fool with puting them on, and taking them off.
http://www.insta-chain.com/
The insta-chain sounds cool and all the ideas about when you are stopped sounds cool also. I was talking to a cop friend last week about snow chains in North Carolina and they are illegal to have on your vehicle. The reason is because the roads are to soft to support the chains. Here is the law regarding the use of snow chains, and snow tires.
§ 20-122. Restrictions as to tire equipment (b) No tire on a vehicle moved on a highway shall have on its periphery any block, stud, flange, cleat or spike or any other protuberance of any material other than rubber which projects beyond the tread of the traction surface of the tire, except that it shall be permissible to use farm machinery with tires having protuberances that will not injure the highway and except also, that it shall be permissible to use tire chains of reasonable proportions or snow tires with metal studs designed to increase traction on ice or snow upon any vehicle when required for safety because of snow, ice or other conditions tending to cause a vehicle to slide or skid. It shall be permissible to use upon any vehicle for increased safety, regular and snow tires with studs which project beyond the tread of the traction surface of the tire not more than one sixteenth of an inch when compressed.
